mustang ii
Mustang II Network Forums - Help with removing crank pulley (hub)
Home | Profile | Register | Active Topics | Members | Search | FAQ
Username:
Password:
Save Password
Forgot your Password?
  Chat Users Online   Click on the Chat link to the left to join.
No users currently logged into chat
 All Forums
 Tech
 General Tech
 New Topic  Reply to Topic
 Printer Friendly
Author Previous Topic Topic Next Topic
azmustang
New Member
USA
Posted - 02/14/2008 :  10:53:06 AM  Show Profile  Reply with Quote
Hi all. I'm in the process of replacing the cam (plastic) and crank gears on Grandma's 74 coupe (2.8 V6).
I'm having problems removing the crank pulley (hub). I removed the center bolt, main pulleys and reinstalled the harmonic balancer with the four bolts so I have something to install the puller on. I have a three jaw puller on the hub with alot of tension and no luck. The haynes manual says the hub is keyed so there really shouldn't be a tight press fit.
Any tricks of the trade getting this off?
AZ Mustang
prostang
Member
Canada
Posted - 02/14/2008 :  2:58:23 PM  Show Profile  Reply with Quote
When you reinstalled the center bolt did you remove the washer so the bolt can go through the center. I have seen this done before this may be your broblem .
Go to Top of Page
beenstanged
Moderator
USA
Posted - 02/14/2008 :  4:34:46 PM  Show Profile  Reply with Quote
while you have tension on puller use a hammer and some safty glasses and tap on puller in the center might shock it off.be careful not to bogger up crank threads that would hurt.tap the front like in this illustration good luck
Edited by - beenstanged on 02/14/2008 4:39:04 PM
Go to Top of Page
1HOTTSHOT
Member
USA
Posted - 02/15/2008 :  12:13:03 AM  Show Profile  Reply with Quote
Have you tried to heat it with a torch? Maybe thatll help, like a littel propane torch.
78 Mustang II Ghia
Go to Top of Page
azmustang
New Member
USA
Posted - 02/19/2008 :  10:14:58 AM  Show Profile  Reply with Quote
I got the pulley and hub off. I just needed a better puller. Thanks for the advice.
AZ Mustang
Go to Top of Page
 Printer Friendly
Jump To:
Mustang II Network Forums © Copyright 1999 - 2008 Mustang II Network Go To Top Of Page
Snitz Forums 2000
  Copyright 1999 - 2013 Mustang II Network  -  Privacy Policy
